Sandbox creation not possible after moving/renaming a subproject with Current project configuration
sdenicke
after renaming a subproject via the "Move Subprojects Wizard"
a sandbox creation of the renamed subproject with the current project configuration is not possible
Example:
1)
Moving  /Testing/Testing2/project.pj
to
/Testing/Testinng2/project.pj
2) Create sandbox via GUI and the Create Sanbox Wizard after selecting the renamed subproject in the project view
Preselected Projectname:
Current configuration: Mainline
we get the Error:
 MKS125211: The project file /Testing/Testing2/project.pj is not registered with the current server.
However: With changing the project configuration to Normal (mainline) the sanbox creation is possible. Sandbox creation with CLI (si createsandbox --project=/Testing/Testinng2/project.pj D:\Test) is also possible.
Question: Is this a Bug in the Sandbox Creation Wizard?
Integrity LifeCycle Manager 11.1.0.961
Thanks in advance
awalsh
(To:sdenicke)
Yes, this is a bug in the create sandbox command. Hotfix HF-S160000001-016 is available to fix the defect.
See also:
KCS 259787
