Has anyone had to convert from SNA to TCP/IP?
Trying to find documentation to accomplish this task.
John
John:
Sorry for the late reply to this ... but a transition from SNA to TCP should be pretty easy.
Make sure any firewalls between the host & remote systems allows FTP traffic and the specified port.
At this point, promotions to the remote environment will go over TCP/IP instead of SNA.
Obviously, you can contact Implementer support if you run into any problems.
David
Hello John,
I'm guessing you are specifically asking about Implementer, since Integrity Lifecycle Manager does not run over SNA. Is that correct?
Kael
John:
David
