I've found that It is possible to edit a test step using the CLI with:
tm editresult --stepVerdict="stepID=216:verdict=Passed" --sessionid=228 78.
However when I try an equivalent command using the Java API I get an error:
Could not save modified test result: Invalid step verdict value specified: "stepID=216:verdict=Passed"
Can anyone please advise on the correct syntax to use within the Java API to perform this command?
I'm using ILM version 12 server.
I was able to edit the test step verdict with the following code:
import java.util.*; import com.mks.api.*; import com.mks.api.util.*; import com.mks.api.response.*; public class sample { public static void main(String[] args) { try { Command cmd = new Command("tm", "editresult"); Option testStep = new Option("stepVerdict","stepID=568:verdict=Passed"); Option sessionID = new Option("sessionID","1638"); cmd.addOption(testStep); cmd.addOption(sessionID); cmd.addSelection("572"); IntegrationPointFactory factory = IntegrationPointFactory.getInstance(); IntegrationPoint ip = factory.createIntegrationPoint("localhost", 7001, 4, 16); Session s = ip.createNamedSession("mySession", null, "tester", "password"); CmdRunner cr = s.createCmdRunner(); Response r = cr.execute(cmd); Result res = r.getResult(); ResponseUtil.printResult(res, 1, System.out); } catch (APIException e) { ResponseUtil.printAPIException(e, 1, System.out); } } }
The output is:
Result: Message = Edited test result
The output is:
Thank you very much and I can confirm this works perfectly.
