User is getting a "Address already in use: JVM_Bind" error when the client launches. The client appears to be installed correctly and the user has access to the installation directory. Below are the log entries:
Integrity Client starting ...
Loading properties from C:\Program Files (x86)\Integrity\IntegrityClient10\IntegrityClientSite.rc
Loading: mks.ic.common.daemon.CommonConfiguration
Loading: mks.ic.aaa.daemon.AaConfiguration
Loading: mks.ic.si.daemon.SiConfiguration
Loading: mks.ic.sd.daemon.SdConfiguration
Loading: mks.ic.ci.daemon.CiConfiguration
Loading: mks.ic.ci.daemon.RqConfiguration
Loading: mks.ic.ci.daemon.TmConfiguration
Loading: mks.ic.api.daemon.ApiConfiguration
2016-06-15 06:09:39,340 (main) GENERAL(10): OnlyOneSessionPolicy loaded
2016-06-15 06:09:39,470 (main) GENERAL(10): Starting HTTP daemon
2016-06-15 06:09:39,589 (main) GENERAL(10): Server loaded configuration file: C:\Users\AD64106.ad\IntegrityClient.rc.
2016-06-15 06:09:39,767 (main) GENERAL(10): ICNoAuthenticationPolicy loaded
2016-06-15 06:09:39,782 (main) GENERAL(10): ICLocalConnectionPolicy loaded.
Cannot create daemon: Address already in use: JVM_Bind
2016-06-15 06:09:39,827 (main) ERROR(0) java.net.BindException: java.net.BindException: Address already in use: JVM_Bind
at java.net.DualStackPlainSocketImpl.bind0(Native Method)
at java.net.DualStackPlainSocketImpl.socketBind(DualStackPlainSocketImpl.java:106)
at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:382)
at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:190)
at java.net.ServerSocket.bind(ServerSocket.java:375)
at java.net.ServerSocket.<init>(ServerSocket.java:237)
at java.net.ServerSocket.<init>(ServerSocket.java:128)
at mks.net.http.HttpServer.<init>(HttpServer.java:164)
at mks.net.http.HttpServer.<init>(HttpServer.java:127)
at mks.ic.common.daemon.Daemon.<init>(Daemon.java:189)
at mks.ic.common.daemon.CommonConfiguration.startServices(CommonConfiguration.java:84)
at mks.frame.app.model.App.startServices(App.java:495)
at mks.ic.common.daemon.IntegrityClient.startupStandaloneClient(IntegrityClient.java:438)
at mks.ic.common.daemon.IntegrityClient.main(IntegrityClient.java:159)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:483)
at com.zerog.lax.LAX.launch(DashoA10*..)
at com.zerog.lax.LAX.main(DashoA10*..)
Hello Jennifer O'dell,
Have you searched the Integrity Knowledge Base? A search for "Address already in use: JVM_Bind" returns CS117504 as the first hit. I think that article should help you resolve your issue.
Kael
In our environment the most frequent reason for this error is that another integrity process is already running at this machine. Maybe its another user, whcih had started integrity and doesnt close the application and a new user is logging in and try to use Integrity also. So if you are using Windows just look at the taskmanager (and be sure to look at processes for all users) and search for some integrity process.
kind regards, Jens
It's also possible that there is another process entirely using the client port (the default port used is 31000).
Kael
