Hi all,
I know that Test Result has some limitations to improve performance but I don't remember if it's history is registred or not.
Is it possible to view a Test Result History?
The end user is questioning that he didn't change a Test Result but the 'Result Modified by' field is showing his name.
Regards.
Test Results have no recorded history. Only the last modified date and user are saved when a result is edited.
Any update to the Test Result will set the modified date and user, not just changing the Verdict.
