Analytics projects typically involve using the Analytics API rather than the Analytics Builder to accomplish different tasks.
The attached documentation provides examples of code snippets that can be used to automate the most common analytics tasks on a project such as:
The documentation also provides examples that are specific to time series datasets.
The attached .zip file contains both the document as well as some entities that you need to import in ThingWorx to access the services provided in the examples.
