This is going to cover one way of configuring an SSL passthrough using HAProxy. This guide is intended to be a reference document, and administrators looking to configure an SSL passthrough should make sure the end solution meets both their company's business and security needs.
Why use SSL Passthrough instead of SSL Termination?
The main reason for ThingWorx would be if a company requires encrypted communication internally, as well as externally. With SSL Termination, the request between the load balancer and the client is encrypted. But the load balancer takes on the role to decrypt and passes that back to the server. With SSL Passthrough, the request goes through the load balancer as is, and the decryption happens on the ThingWorx Application server.
What you will need to continue with this guide:
With ThingWorx running as SSL and HAProxy installed, we just need to make sure the HAProxy configuration is setup to allow SSL traffic through. We use 'mode tcp' to accomplish this.
On your HAProxy machine, open /etc/haproxy/haproxy.cfg for editing. While most of this can be customized to fit your business needs, some variation of the highlighted portions below need to be included in your final configuration:
global
log /dev/log local0
log /dev/log local1 notice
chroot /var/lib/haproxy
stats socket /run/haproxy/admin.sock mode 660 level admin
stats timeout 30s
user haproxy
group haproxy
daemon
# Default SSL material locations
ca-base /etc/ssl/certs
crt-base /etc/ssl/private
# Default ciphers to use on SSL-enabled listening sockets.
# For more information, see ciphers(1SSL). This list is from:
# https://hynek.me/articles/hardening-your-web-servers-ssl-ciphers/
# An alternative list with additional directives can be obtained from
# https://mozilla.github.io/server-side-tls/ssl-config-generator/?server=haproxy
ssl-default-bind-ciphers ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:RSA+AESGCM:RSA+AES:!aNULL:!MD5:!DSS
ssl-default-bind-options no-sslv3
defaults
log global
option tcplog
mode tcp
option http-server-close
timeout connect 1s
timeout client 20s
timeout server 20s
timeout client-fin 20s
timeout tunnel 1h
errorfile 400 /etc/haproxy/errors/400.http
errorfile 403 /etc/haproxy/errors/403.http
errorfile 408 /etc/haproxy/errors/408.http
errorfile 500 /etc/haproxy/errors/500.http
errorfile 502 /etc/haproxy/errors/502.http
errorfile 503 /etc/haproxy/errors/503.http
errorfile 504 /etc/haproxy/errors/504.http
frontend https
bind *:443
mode tcp
default_backend bk_app
backend bk_app
mode tcp
server TWXAPP01 <twxapp01IP>:<port>
In this example, the user would connect to https://<loadbalancer>/Thingworx and the load balancer would forward the requests to https://<twxapp01IP>:<port>/Thingworx
That’s it!
A couple of side notes:
