- There are multiples approaches to improve the performance
- Increase the NetWork bandwidth between client PC and ThingWorx Server
- Reduce the unnecessary handover when client submit requests to ThingWorx server through NetWork
- Here are suggestions to reduce the unnecessary handover between client and server
- Eliminate the use of proxy servers between client and ThingWorx
- It is compulsory to download Combined.version.date.xxx.xxx.js file when the first time to load mashup page (TTFB and Content Download time).
- Loading performance is affected by using of proxy servers between client and ThingWorx Server.
- This is testing result with proxy server set up
![User-added image](https://support.ptc.com/images/cs/articles/2017/03/13060434_hpsr.png)
- This is the test result after eliminiating proxy server from the same environment
- Cut off extensions that not used in ThingWorx server
- After installed extensions, the size of Combined.version.date.xxx.xxx.js increased
- Avoid Http/Https request errors
![User-added image](https://support.ptc.com/images/cs/articles/2017/03/13060537_MiOF.png)
- There is a https request error when calling Google map. It takes more than 20 seconds
Last update:
Mar 27, 2017
02:11 AM
