Audit Entry to CSV
No ratings
This script creates a csv file from the audit log filtered by the User Access category, so dates of when users logged in or logged out.
*** see update below *** Note:  The csv file has the same name as the Groovy script and does NOT have the .csv extension . To get the .csv extension, the Groovy script has to be renamed to AuditEntryToCSV.csv.groovy .  Suggestions on how to improve this are welcome.
*** Update ***: The download works without the renamed groovy script by returning text instead of an input stream.  The script has been modified to illustrate this.
Parameters:
  1. days - the number of days past to fetch audit logs
  2. model_name - the model name of the asset
  3. serial_number - the serial number of the asset
import com.axeda.drm.sdk.device.ModelFinder
import com.axeda.drm.sdk.Context
import com.axeda.common.sdk.id.Identifier
import com.axeda.drm.sdk.device.DeviceFinder
import com.axeda.drm.sdk.audit.AuditCategoryList
import com.axeda.drm.sdk.audit.AuditEntryFinder
import com.axeda.drm.sdk.audit.SortType
import groovy.xml.MarkupBuilder
import com.axeda.platform.sdk.v1.services.ServiceFactory
* AuditEntryToCSV.groovy
* Creates a csv file from the audit log filtered by the User Access category, so dates of when users logged in or logged out.
* @param days        -   (REQ):Str number of days to search.
* @param model_name        -   (REQ):Str name of the model.
* @param serial_number        -   (REQ):Str serial number of the device.
* @note - the csv file has the same name as the Groovy script and does NOT have the .csv extension . To get
* the .csv extension, the Groovy script has to be renamed to AuditEntryToCSV.csv.groovy .
* @author Sara Streeter <sstreeter@axeda.com>
def writer = new StringWriter()
def xml = new MarkupBuilder(writer)
try {
   def ctx = Context.getUserContext()
   ModelFinder modelFinder = new ModelFinder(ctx)
   modelFinder.setName(parameters.model_name)
   Model model = modelFinder.find()
   DeviceFinder deviceFinder = new DeviceFinder(ctx)
   deviceFinder.setSerialNumber(parameters.serial_number)
   Device device = deviceFinder.find()
   AuditCategoryList acl = new AuditCategoryList()
   acl.add(AuditCategory.USER_ACCESS)
   long now = System.currentTimeMillis()
   Date today = new Date(now)
   def paramdays = parameters.days ? parameters.days: 5
   long days = 1000 * 60 * 60 * 24 * Integer.valueOf(paramdays)
   AuditEntryFinder aef = new AuditEntryFinder(ctx)
   aef.setCategories(acl)
   aef.setToDate(today)
   aef.setFromDate(new Date(now - (days)))
   aef.setSortType(SortType.DATE)
   aef.sortDescending()
   List<AuditEntry> audits = aef.findAll()
// use a Data Accumulator to store the information
def dataStoreIdentifier = "FILE-CSV-audit_log"
def daSvc = new ServiceFactory().dataAccumulatorService
if (daSvc.doesAccumulationExist(dataStoreIdentifier, device.id.value)) {
    daSvc.deleteAccumulation(dataStoreIdentifier, device.id.value)
// assemble the response
   audits.each { AuditEntry audit ->
           def row = [
               audit?.id.value,
               audit?.user?.username,
               audit?.date,
               audit?.category?.bundleKey,
               audit?.message
        row = row.join(',')
        row += '\n'
        daSvc.writeChunk(dataStoreIdentifier, device.id.value, row);
// stream the data accumulator to create the file
   InputStream is = daSvc.streamAccumulation(dataStoreIdentifier, device.id.value)
return ['Content-Type': 'text/csv', 'Content-Disposition':'attachment; filename=AuditEntryCSVFile.csv', 'Content': is.text]
} catch (def ex) {
   xml.Response() {
       Fault {
           Code('Groovy Exception')
           Message(ex.getMessage())
           StringWriter sw = new StringWriter();
           PrintWriter pw = new PrintWriter(sw);
           ex.printStackTrace(pw);
           Detail(sw.toString())
logger.info(writer.toString())
Version history
Last update:
‎May 10, 2016 12:24 PM
Updated by:
Labels (2)
