The following script is a component of the Axeda Connected Configuration (CMDB) feature. It is used to provide configuration data for controlling package deployments via Connected Content (SCM).
ConfigItem_CRU.groovy
*Takes a POST request, not parameters
import static com.axeda.sdk.v2.dsl.Bridges.*
import com.axeda.drm.sdk.scripto.Request
import com.axeda.services.v2.ConfigurationItem
import com.axeda.services.v2.ConfigurationItemCriteria
import com.axeda.services.v2.AssetConfiguration
import com.axeda.services.v2.ExecutionResult
import groovy.json.JsonSlurper
import net.sf.json.JSONObject
import groovy.xml.MarkupBuilder
* ConfigItem_CRU.groovy
* Reads in json from an http post request and reads, adds, deletes or updates Configuration Items.
* @note this parses a post and does not take any additional parameters.
* @author sara streeter <sstreeter@axeda.com>
def contentType = "application/json"
final def serviceName = "ConfigItem_CRU"
def response = [:]
def writer = new StringWriter()
def xml = new MarkupBuilder(writer)
try {
// BUSINESS LOGIC BEGIN
def assetId
def validationOnly
def validationResponse = ""
List<ConfigurationItem> configItemList
if (Request?.body != null && Request?.body !="") {
def slurper = new JsonSlurper()
def request = slurper.parseText(Request?.body)
assetId = request.result.assetId
validationOnly = request.result.validationOnly?.toBoolean()
if (request.result.items != null && request.result.items.size() > 0){
configItemList = request.result.items.inject([]) { target, item ->
if (item && item.path != "" && item.key != "" && item.path != null && item.key != null){
ConfigurationItem configItem = new ConfigurationItem()
configItem.path = item.path + item.key
configItem.value = item.value
target << configItem
target
if (assetId != null) {
def asset = assetBridge.find([assetId])[0]
AssetConfiguration config = assetConfigurationBridge.getAssetConfiguration(assetId, "")
def itemToDelete
if (config == null) {
createConfigXML(xml)
AssetConfiguration configToCreate = assetConfigurationBridge.fromXml(writer.toString(), asset.id)
ExecutionResult result = assetConfigurationBridge.create(configToCreate)
AssetConfiguration config2 = assetConfigurationBridge.getAssetConfiguration(asset.id, "")
config = config2
itemToDelete = "/Item"
if (configItemList != null && configItemList?.size() > 0){
List<ConfigurationItem> compareList = config.items
def intersectingCompareItems = compareList.inject(["save": [], "delete": []]) { map, item ->
// find whether to delete
def foundItem = configItemList.findAll{ compare -> item?.path == compare?.path && item?.value == compare?.value }
map[foundItem.size() > 0 ? "save" : "delete"] << item
map
intersectingCompareItems.delete = intersectingCompareItems.delete.collect{it.path}
if (itemToDelete){
intersectingCompareItems.delete.add(itemToDelete)
def intersectingConfigItems = configItemList.inject(["old": [], "new": []]) { map, item ->
// find whether it's old
def foundItem = compareList.findAll{ compare -> item?.path == compare?.path && item?.value == compare?.value }
map[foundItem.size() > 0 ? "old" : "new"] << item
map
assetConfigurationBridge.deleteConfigurationItems(config, intersectingCompareItems.delete)
assetConfigurationBridge.appendConfigurationItems(config, intersectingConfigItems.new)
def exResult = assetConfigurationBridge.validate(config)
if (exResult.successful){
validationResponse = "success"
if (!validationOnly){
assetConfigurationBridge.update(config)
else {
validationResponse = exResult.failures[0]?.details
response = [
assetId: assetId,
items: config?.items?.collect { item ->
def origpath = item.path
def lastSlash = origpath.lastIndexOf("/")
def key = origpath.substring(lastSlash + 1, origpath.length())
def path = origpath.replace("/" + key, "")
path += "/"
path: path,
key: key,
value: item.value
validationResponse: validationResponse
else {
throw new Exception("Error: Asset Id must be provided.")
catch (Exception ex) {
logger.error ex
response = [
error: [
type: "Backend Application Error"
, msg: ex.getLocalizedMessage()
return ['Content-Type': 'application/json', 'Content': JSONObject.fromObject(response).toString(2)]
* Create the Success response.
* @param xml : The xml response.<br>
* @param info : If this is set to "1" the info element will be included in the response.<br>
* @param infos : Collection of information to include within the info element of the response.<br>
private void createConfigXML(xml) {
xml.Item()
Thanks for this topic.
I have one question :
