Sunshine, beach chairs & ThingWorx 9.2. What more could you need for your summer essentials?
Targeted for June 2021, our next release features intelligent one-click deploy with Solution Central*, new web components, and an enhanced IAM integration!
Let’s dive deeper into each.
- Deploy an entire solution in one click with Solution Central’s intelligent one-click deploy.
Good news: you followed a modular design pattern and broke up your application into smaller libraries and components. You can now enjoy easier maintenance and re-use of your app. Bad news: your app now has 10 different dependencies, with differing versions, each with a required order to import into ThingWorx. Now, try to share these modules with colleagues, or use them on environments where code may already exist. Not exactly a day at the beach, right? Fear not, one-click deploy has you covered. You click the button, we spin through and find the right dependencies, the right versions, the right order and load them all into the target platform upon a deploy request. Solution Central one-click deploy means more sun and sand for you! Check out this post to learn more about what’s available in Solution Central 3.0!
Intelligent One-Click Deploy with Solution Central
- Enhance your solutions with our latest web components!
Imagine this: you’re a systems developer at a large parts manufacturer and your boss has asked for a detailed analysis of downtime over the last six months. Not to worry! ThingWorx 9.2 features a new waterfall chart that can be leveraged to understand dynamics in defect counts, loss reasons, time bottlenecks and other conditions. Be sure to try it out! And, while you’re at it, try out our new web components that are available now as preview: a toolbar to add key like filtering at the top of your screen or data intensive widgets (e.g., grids), a more flexible grid and a fancy new paradigm for interface developers. These three preview widgets are fully functional and tested in 9.2. Preview widgets will graduate in a future release when we add all planned functionality or address any perceived usability feedback. Don’t be afraid—it just means more good things are coming. Surf’s up, you can use these widgets safely now!
New Waterfall Widget Coming in ThingWorx 9.2
- Leverage new integrations with Azure Active Directory for more seamless user management.
In prior releases we have offered integration to Azure Active Directory and SSO through Central Authorization Service type products or through custom authenticator extensions to ThingWorx. With our new Azure AD integration, you can cut the custom extensions and additional software out of the picture. We now accept direct SAML assertions from Azure AD directly to ThingWorx platform, which makes it that much easier to deploy your app in your organization’s SSO flow. It’s as smooth as that frosty tropical drink when the sun goes down.
Like what you see? Want to try it out for yourself? ThingWorx 9.2 is targeted for June 2021, so be sure to keep a lookout on the horizon. Bump, set, spike!
Stay cool & connected,
Kaya
Comments
May 27, 2021
04:31 PM
What's the release date for 9.2 please?
