Bend lines in ProE Wildfire 3 drawings
ptc-1171900
I am trying to use the sheet materials application to create a layout for a polypropylene net, to be cut on a laser cutter. I have put a 0.00 mm radius on the inside face of what will be a 30 degree bend, with the intention of setting the laser cutter to engrave this line - unfortunately, when transferred to the drawing interface this is always displayed as two lines, presumably representing the external curve 'edges' - is there anyway of simply seeing a single bend line? (I have already tried a number of things including changing the relief settings with no luck)
John, If you show the bend axis and hide the tangent edges this might achieve what you are looking for. Email me if you need any more help on this. Andy
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
