Detail Drawing Active Model
CBenner
Question: On a detail drawing with multiple sheets, each sheet having a different model (sub-assembly or part) being detailed on it.... is there any way for Pro-E to know what model is on each sheet, so you don't have to remember (ie: before balooning or adding a BOM) to select the current model from the list at the bottom of the sheet. It would be so nice if, once you place a view on a sheet,... that model is always the "current" model for that sheet.
Chris Benner
Designer II
Powell Fabrication & Manufacturing, Inc.
<u>www.powellfab.com
P: 989-681-2158
F: 989-681-5013
</u>
Chris Benner
Autodesk ® Expert Elite
Left click once on the drawing view and then RMB (hold) and select "View Info" - this will tell you the following:
- View model
- View name
- View type
- Simplified Rep (if any)
- Sheet Number
- Exploded State info
- View Display info
- Layer info
Bob
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
