Help!
ptc-1089469
Help!
Hi folks,
I'm trying to modify a PP to run on a Mach3 controller. Does anybody know how to output a G28 code along with the M06 tool change code in GPOST?
Any help would be fantastic.
Cheers,
Steven
Steven Dibdin
Design Prototyping Manager
S M A R T D E S I G N
601 W. 26th Street, 18th Floor
New York, NY 10001
T 862 684 1166 direct
T 212 807 8150 indirect
New York * San Francisco * Barcelona
smartdesignworldwide.com
Mach 3 should work with a standard fanuc 3 axis post. Why do you want the
tool to "G28 go to home position" and tool change on the same line?
Terry Thomas
CNC Programmer
Maxton Manufacturing
So Francois FIL text solution worked a treat. Syntax added was:
T1=TEXT/'M06'
T2=TEXT/'G28M06';REPLAC/T1,T2
Output the G28 code just where we needed it.
Thanks to everyone who responded.
Cheers,
Steven
Steven Dibdin
New York, NY 10001
