Wildfire 2.0 M150
I got over my Gpost Option File Generator not opening by installing an old disc of 2001 that I had and got it to work outside Pro/E. Now, there is another problem.
When I try to use the post, it doesn't work. So, I figured that I would eliminate the MACHIN option, then pick the post manually. However, that is where the error seems to originate. I get a command prompt error that <post directory=">//dblist.bat is not a valid batch file.
I have never had this happen on any of the other machines that I have Pro installed on, and I am at a total loss.
Any help at all would be greatly appreciated.
WMF
