Does anyone know how to use Pro/Man to program a 5 axis grinder? I know
how to program it by treating the wheel as an endmill. This is fine for
most stuff but I would prefer to be able to say "pro/man, the tool now
rotates about the x axis" and then model the tool as a key cutter. And
bam, I would be able to see my toolpath more accurately prior to leaving
my desk.
Thank you in advance,
Kevin
This e-mail and any attachments are intended only for the individual or company to which it is addressed and may contain
information which is privileged, confidential and prohibited from disclosure or unauthorized use under applicable law. If you are not the intended recipient of this e-mail, you are hereby notified that any use, dissemination, or copying of this e-mail or the information contained in this e-mail is strictly prohibited by the sender. If you have received this transmission in error, please return the material received to the sender and delete all copies from your system.
