Hi Rob,
If you setup a multiple tip thread tool, in "Define Thread" you can setup
the cut motion as interrupted (rather than the default continuous). That way
all teeth are used, then the tool moves off the cut, then onto the next set
of teeth. You can also control the overlap in this case.
Climb/Conventional controls whether the cut goes from the top-down or
bottom-up (of course along with internal/external and spindle rotation).
I hope this helps.
Charles
Charles Farah
Sigmaxim, Inc. www.sigmaxim.com
1895 Centre St, Suite 102, Boston, MA 02132
(Tel) 781-329-5235 877-SIGMAXIM
(Fax) 781-329-9511
