constructing datum curves in Pro-E...
RickKroger
In earlier versions of Pro-e (modeling) you could select edges of a model and create them into a datum curve and select that datum curve in Pro-manufacturing (milling) to construct tool path. This option seems no longer available. Pro-e only allows datum curves to be comstructed by: through points, sketch, from file or from calculation. Is it possible to consrtuct a curve by simply picking edges? HELP.
Hi Rick, move the mouse pointer to a edges. Click with the left mouse button and then move a little bit the mouse pointer. Now the edges will be highlighted. Click again with the left mouse button. Choose Edit->Copy & Edit->Past Good Luck! Regards Jürgen
THANKS. this works well.
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
