constructing datum curves in Pro-E...
RickKroger
In earlier versions of Pro-e (modeling) you could select edges of a model and create them into a datum curve and select that datum curve in Pro-manufacturing (milling) to construct tool path. This option seems no longer available. Pro-e only allows datum curves to be comstructed by: through points, sketch, from file or from calculation. Is it possible to consrtuct a curve by simply picking edges? HELP.
YOu can still create datum curve thru edges. But the process is changed you need to copy the edges and paste it back to create the datum curve from the edges.
I'm not sure I follow what you mean. Can you explain more?
I tried messing with it more and got it figured out. MANY THANKS.
