Hello Group,
Iâ≢m new to this forum. Iâ≢ve just signed up today. I have been a member in the Model and pro manufacturing forums for awhile now. I think this is a fabulous resource. Iâ≢m fairly new to pro/e so my question may seem basic. I need some help understanding how parameters behave.
What I mean isââ¾.how are they read into or from the start drawing Template and drawing format as the part model is brought into my template? First a couple of quick points â≠one, we are not using PDMLink or IntraLINK. Two, I know how to create a parameter using the tools > parameter menu. I have been experimenting with different parameters and set-ups. Iâ≢veâ≢ gotten close to what I want but Iâ≢m just missing something.
What I really need is for pro/e to prompt me to enter the string values for paramâ≢s in my title block. I have something that is close now but for some reason I have to select the parameter type ââ¬Ã
Âstring, real number, ect. Is there a way to tell pro the type beforehand so that I donâ≢t have to select a type for each parameter in my title block? Currently the config option ââ¬Ã
Âmake_parameters_from_fmt_tablesââˆis set to YES. I have tried placing the paramâ≢s in the actual title block within the format and not in the template & vice versa. Similarly, Iâ≢ve tried putting them within the Tools > Parameters menu in both the format and the template â≠tried tools > paramâ≢s within just the Template and not the Format. Iâ≢ve tried placing the ââ¬Ã
Â&ââˆstatements in the title block in conjunction with creating the parameter in the tools menu. I select the string option â≠I leave the value box empty, but I canâ≢t get pro/e to prompt me for the value without re-defining the param type.
I just donâ≢t understand the ââ¬Ã
Âchain of commandââˆfor how parameters are read. Format first then template? Is it the ââ¬Ã
Â&ââˆstatements within the Title block then the settings in the Tools > Parameters menu? How do I arrange all these different locations for parameters and their values to get what I need?
Can someone give me a road map to help me understand this control â≠I have tried so many different arrangements and configurations to attempt to gain an understanding that I have fully confused myself and I am currently baffled by this.
Thanks in advance.
Tracy Willis
