I have a question with the "Find" command.
I have my Model tree as a separate window and just notice that the "Find"
command thru the model tree is different than the "Find" command thru the
Edit>Find in the main window. I created a map key using the model tree's
Find command and it works.
I passed along the map key to a coworker to use but it does not work like
how it does on my machine. I realize that he does not use Model tree as a
separate window. So I reedit the map key but notice that the Find command
thru the main window is different and does not have the option I am looking
for.
The option I am looking for is the Select All key. Am I over looking
something in the main window Find?
Son Nguyen
