roll back an mfg file.
cncwhiz
I have not flushed out the folder that I am working in and want to roll it back a few days. I tried using the older mfg version buy putting a .old after the newer mfg files. I did the same thing to the tool path and neither one changed to the older version. Which file do I need to roll back ?
Open an Explorer window and sort the Pro/E files by date/time.
Then just move all the file versions after a certain date/time to a temp folder.
