"Tom Gutman" wrote:
Mathcad has a long history of problems with 3D plots. Visit the Collaboratory and look up a number of old threads on the subject. Your symptoms suggest that you have the problem where the frame is drawn with fill, and in front of the actual graph. Change the graph options to remove the frame and see if it works then.
"Richard Jackson" wrote:
Are you new to Mathcad? Have you done 3D plots before? I have to ask, because some aspects of 3D plots are not all that obvious, and we need to be sure there is a real problem. Richard
"John Case" wrote:
You might try going into /control panel/display/settings and turning off hardward acceleration. I have found sometimes that 3d won't work when "hardware acceleration" is turned on.
"Tony Aponick" wrote:
Going to 16 bit from 32 bit color worked for me. With some of the new graphics cards you cannot disable acceleration, but you can control color depth. Win 7, 64 bit, Mathcad 14 ATI FirePro 8700. All this horsepower, and you make it look like a win 95 clunker. But Mathcad apparently only uses 16 bit anyway.
This also worked for me but it was not easy to change the display settings in win 7 at least for me. The following link gives a detailed point and click about changing the hardware acceleration - which for some reason I can't do but an intermediate step is to change the color setting back and forth from 16 to 32 bits.
http://help.aol.com/help/microsites/microsite.do?cmd=displayKC&docType=kc&externalId=15392
