Bad Function
PhilipLeitch
2-Explorer
Bad Function
"Bad function"
Function(�sit�), Function(�STAY�)
Function("come boy")
GOOD FUNCTION!
Or is it more like �This is a bad %$# Function� I wouldn�t want to cross hash its object at night.
Seriously though... I'm not sure how a function can be "bad". It's like the old "Bad Command or File Name" - no it's NOT bad, it's just wrong.
Philip
___________________
Nobody can hear you scream in Euclidean space.
It turns out I had something like this:
c(X):= stuff
d(X):= yadda
f(X):= blah + d(X)
D(X):= d(X)-f(X)-C(X)
I'm not sure why it fell down, but it couldn't recognise that C wasn't defined as a function.
If I do this at the very top of a blank worksheet:
Y(X)=
I get an error stating that "this variable is undefined", but this:
C(X)=
Gives the bad function error... just does't like it.. C?
Philip
___________________
On 8/27/2009 1:49:33 AM, pleitch wrote:
>"Bad function"
>Function(�sit�),
>Function(�STAY�)
>GOOD FUNCTION!
Sad to say, but that's exactly what went through
my head when I saw the topic title 😞
Yeah. It obviously came from a bad neighbourhood,
always picking arguments, causing division
wherever it goes,
The Law says that you've got to obey the Syntax.
You didn't obey the Syntax. You broke the Law and
that's Bad.
... well, OK; there are a couple of laws hanging
around from the 11th century that need cleaning up
and there are some errors in the current
legislation
However, ...
>like this:
>c(X):= stuff
>d(X):= yadda
>f(X):= blah + d(X)
>function.
>Y(X)=
>but this:
>C(X)=
>C?
Probably because 'C' is a unit, the coulomb and
'c' is the speed of light. It appears to give a
'bad' function whenever a constant is misused as a
function (try defining z:=3 then using that as
z(X)). Y, OTOH, is simply undefined.
Stuart
