Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I am trying to carry over to the next line a portion of a long boolean equation that spreads over to the next page. What I really need is to insert some sort of carriage return, but I don’t know how to do this in a boolean equation. Any hint?
