This work sheet is for the tool box. It implements several of the Mathcad advanced concepts and functionalities. Look at EQ.1, 2, 3 and their construct (in collaboration). Then calculating several CreateMesh on the range b:=0..3, then the plot on grids or plot on labels (mesh), some pre-oriented 3D, then spooling into file and exploding back from file. The work is administrated in MDA style [Multi Dimensional Array].
The S(fZ,s0,s1,t0,t1,xmesh,ymesh,b) is the 100% equivalent of the Mathcad built-in CreateMesh, except it allows the ranged parameter b:=0.. to be introduced . The Mathcad built-in does not allow a ranged parameter, rather the option is for a scalar function [example rotation]. It should work in Mathcad 14 as it borrows no function specific to version 14.
Enjoy your week end and this work sheet.
jmG
