I have used the "regress" function to generate a cubic surface for a set of data and have plotted the results.
The regress function provide a vector with the coefficients for the surface polynomial. However it does not specify the variable names for each coefficient. I need to know the variable names for a paper I am writing.
Also is there a standard format for the form of a polynomial equation generated by MCAD for other polynomial degrees ??
See attached file
John Clark
www.clark-engineeers.com
