Drawing sketches or creating diagrams
Voyager77-disab
I'm new to MathCAD and would like to use it for homework in a CE structural engineering course I am taking. I have thus far been unable to find a means to draw simple diagrams or sketches in MathCAD to supplement the calculations and text. A search found reference to SmartSketch LE from Intergraph, but communication with them indicates that this software is no longer sold. The full SmartSketch package costs ~$1500, which is out of my reach.
Is there a less expensive means to create or import diagrams into MathCAD? I'm looking to do simple things like cross sections for moment of inertia calculations, free-body diagrams, etc.
Voyager77
9 REPLIES 9
I have always used either Presentation, or Power Point. Create drawing, select and copy to clipboard. Return to MathCad and find a clear space and hit paste. Select picture or bitmap. You can then move the drawing (grab edge) and size it (grab handles).
Physics: Common Sense made Obscure by Mathematics Don Sparlin
I was hoping for something more CAD-like, but it is good to know that this will work in a pinch.
Voyager77
>a pinch.
>Thanks,
>Voyager77
There are plenty of free CAD programs on the web:
http://www.cadstd.com/?sender=adwords
TTFN,
Eden
If you have access to a CAD program, go ahead and use it. I will often plot CAD drawings or sketches to PDF, or even format with a white background and do a screenshot. Then you can copy/paste the image right into the document.
Preston
I use CorelDraw. It's not CAD, but it can do 3D extrusions, dimensions, etc.
Any drawing package should work. Just copy and paste the drawing as a metafile (not as a bitmap, which will potentially make the Mathcad file very large).
Richard
SteenGroðe
6-Contributor
(To:RichardJ)
I use Smartsketch...
ChrisKaswer
(To:SteenGroðe)
SmartSketch used to have a bi-directional API to Mathcad...back in the day...ah yes, the good ole days!
OK.
Would you want to paste it as a native object rather than a picture or bitmap? Would this allow future editing and reduce the size of the document?
Stuart
I was thinking of using creo for quick schematics. I haven't used it yet. But I think they have free student versions.
It's by PTC.
https://www.ptc.com/en/products/creo/schematics
