Electric field
honex-disabled
Electric field
I really need an urgent respond to this question.I have tried to analyse it as follows:
since the charge is at the centre of the cube, the distance of the charge to each face of the cube is 5cm (given the side to be 10cm). I got the answers to be (i)zero (ii)452000Nm2/C
A 60microcoulomb charge is at the centre of a cube of side 10cm.(i)What is the total flux through the cube? (ii) What is the flux through one face?
6 REPLIES 6
That's not an analysis, that's a statement of the solution.
Been a long time since I looked at this kind of stuff, but I reckon (ii) is about 2.5 times too low. How do you get a total flux of zero if the cube encloses the charge?
Stuart
Size of cube doesn't matter!
(i) q/epsilon_0
(ii) (1/6)(q/epsilon_0)
(Gauss theorem)
Saludos,
Al
Asking homework questions on this forum, particularly ones which don't require Mathcad, is generally frowned upon here.
Good luck with your homework set or exam.
- Guy
>exam.
> - Guy
_______________________________
Is it reasonable that the total flux through the cube is the same as it is through a sphere ? Maybe not, but the book should tell. Maybe not if the cube is a Faraday cage ? The other answer: there is no flux w/o work sheet.
jmG
Lets put a small sheet with educational purposes both in Physics and Mathcad calcs.
Expressions are not simplified or optimized in order to show the most direct translation of Physics equations...
Saludos,
Al
>Lets put a small sheet with educational purposes both in Physics and Mathcad calcs <<br> _____________________________
Most interesting but way above my head !
jmG
