"Paul Hunter" wrote:
Richard, I have compressed the file and uploaded. You can see that the calculated results are similar for all cases. I addition I have benchmarked the results against an online calculator and all apears to be ok. My problem is with getting the software to define the units. I can only get the equations to work if I use unitless variables
