Given Find Failure
ptc-1368288
Given Find Failure
"The matter here is not about extracting the closed contour, it is done otherwise. Rather, it concerns the closed contour that Given/Find does not solve. I have tried almost anything in the program style below, not to avail. Easy to see that the free flying version and the programmed one don't scan in the same way. The programmed version has no liberty to spread either x, or y ... therefore no solution can be found as there are in fact no exact pairs ... most interesting ! "
jmG
... the problem has been solved (solved !)
It simply shows the difficulty of initializing the solver. Not so much interesting in the case of this closed contour. However few more critical real applications have been found of great difficulty to initialize. For this example, "datanew" does not seems to be a candidate for further processing.
jmG
