How to Copy/Paste Equations from PTC Mathcad (ver. 7) into Word, Powerpoint, or similar?
  • October 28, 2021
  • 6 replies
  • 10219 views
I'm using PTC Mathcad version 7 and would like to copy and then paste equations into my Power Point slides.   This was possible with the normal MathCAD (Such as MathCAD 15 and previous versions of the old MathCAD). However, this doesn't seem possible with PTC Mathcad - or am I wrong about that?   I haven't had much luck using a simple copy/paste method with PTC Mathcad.
Although, I certainly can use another application to create a screen capture - then import that image into Microsoft Word or Power Point - I'd much rather use a command sequence within PTC Mathcad - such as Ctrl-C and Ctrl-V
Since the 1990s Ctrl-C and Ctrl-V worked quite well with original MathCAD for equations, graphs, etc.
Let me know what options exist for exporting equations and graphs out of PTC Mathcad version 7.
Thanks!
I copy and paste as picture!
I don't see how to do that.  I only see Copy and Paste - and those commands do not work with equations or graphs.
You can save your Mathcad Prime worksheet in "RTF" file format ("Save As" --> "RTF").
I'm not following how saving to an RTF format helps with importing into a Microsoft Word or Power Point document.
DJNewman
18-Opal
October 28, 2021
You're having trouble doing this?
PTC Marketer for Creo and Mathcad. I run their YouTube channels, some Creo campaigns, and all Mathcad campaigns and communications.
That's what I said in my first post.
You don't need 'another application' to do a screen capture.
Tick your mouse on the Prime window, to make sure it 'has the focus'. Then press the [Alt]  button and briefly hit the [PrintScreen]  button, then you can let go of the [Alt].
Now you have a screen copy of the Prime window.
Go to Paint (also built into Windows), and do a Paste or [Ctrl-V].
Take the rectangular selection box and select that portion of the window that you need. Do a [Ctrl-C] and go to PowerPoint where you can do a [Ctrl-V]. See result below (left picture).
I'll gladly admit that it is easier in real Mathcad (right picture); took just a simple selection of the two regions, copy, then past in PowerPoint.
Wow, it's been decades since I used alt-Print Screen  to take advantage of Window's built in screen capture mechanism. That's a decent hack to overcome the shortfall of PTC Mathcad.
I'll just use MathCAD 15 - since the original version of MathCAD can easily copy and paste equations and graphs using Ctrl-C and Ctrl-V without all the hoopla associated with screen captures.
If you do not have a full license of Prime, so in effect you're using Prime Express, then the copy-paste functionality is present, but limited to a single item. That is true for Prime - to - Office applications, as well as Prime - to - this forum.
From the above you may conclude that if you do have a full Prime license, copy-paste should work for multiple regions simultaneously...
DJNewman
18-Opal
October 29, 2021
Huh, I didn't even know that was an Express-full difference, but, yeah, I just tested it and you can only copy-paste one item at a time in Express while you can easily multi-select in premium to copy-paste to Word/PowerPoint as my above video showed.
I'll probably get our Express vs. full comparison page updated to document this, then.
But if you do have the full version, there's no print screen button necessary to copy-paste it.
Well, I have no problem doing exactly what you say it doesn't do.  However, note that you must copy/paste only one item at a time.  If you select multiple items it doesn't work - for whatever reason.  Even pasting between multiple sheets of mathcad I've noticed it will sometimes hiccup if pasting multiple items.
Guess you're using Prime Express then, like me... See above.
Nope, full-blown and paid-for v7.  I've never had any prime version successfully paste more than 1 item into MS apps.  I'm only guessing but copy must include some additional mathcad data about relative position or something that other programs can't figure out.
