Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Interpolation
ELSID
Interpolation
There has got to be an easy way of interpolating data in MathCAD 14 M020.
Given the attached image, how would I interpolate the data. I have already calculated the variables theta and Ao/A.
As an example, I calculated theta=7 and Ao/A=4.7
Thank you
6 REPLIES 6
Doesn't make sense. Your worksheet is set up to interpolate for the ratio for θ=20°. But you haven't defined the variables you use for calculating the ratio. So naturally you get errors.
In your post you mention θ=7°. That is not an interpolation, it is way outside the table. And I don't understand θ. The picture seems to show it as the angle between the corner lines. But that cannot exceed 90°, it can't reach the 180° claimed for the abrupt transition.
__________________
� � � � Tom Gutman
ELSID
(To:TomGutman)
Tom,
The angle theta is calculated elsewhere. I am trying to set up a routine that interpolates based off of the chart.Essentially, plot the points, interpolate between the points. I know I posted at 20 degrees, I assumed that as a condition in order to continue with my work. I would like to get an interpolated answer if possible
You can do a bilinear interpolation. That is not provided for directly in Mathcad, but is easy to program. You just need to do a search on the two coordinate vectors to identify the rectangle containing the desired point. If t and s are the fractional distances (between zero and one) from the low X and Y values the weights are just the four combinations of t, s, 1-t, and 1-s.
You can also do a cubic spline interpolation. That is usually more accurate, but also a bit riskier. You need to check the iterpolation to be sure you have not introduced undesired wiggles into the surface. Sometimes you need to transform the coordinates first, to get a better spacing. Mathcad has built in 2D cubic spline for a square data matrix, I have a more general implementation in my cubic spline sheet.
But you still have the issue that 7° is outside the table and calls for extrapolation, not interpolation. And an extrapolation that is large enough to make it very questionable. And I still don't understand θ, based on the diagram and the presented values.
__________________
� � � � Tom Gutman
1. Augment the data table for 0�
2. Spline ... lspline in the program
Done
jmG
jmG
ELSID
(To:ptc-1368288)
jmG
Appears to be an elegant approach to the solution. Now I will try and decipher your use of Matrices to solve my question. Documentation is seriously lacking for MathCAD!
