Each time I open MP or Help, it is set to its default view, even after I have changed the window sizes. Related to this is an oddity in Help. When I start Help, the Search dialog is visible in a little narrow window pane in the upper left of Help. I can see the whole of the Search dialog by moving the top of the Search results dialog downward, but when I exit to the system tray and then re-open Help, the Search dialog is nearly hidden again.
Rich
http://www.downeastengineering.com/
