Mathcad links with Prode Physical Properties
- December 17, 2012
- 17 replies
- 7317 views
I have some exciting news for chemical engineers. The Prode Physical Properties (PPP) program and databank has been linked to Mathcad 15 via a dll. Now, for a fairly reasonable price (about $400 US), you can have access to physical property data for 1635 components and over 200 functions to access data and set values in the databank and in streams, perform flashes and other process operations.
PTC and I have been building the dll linking file for several months. I purchased the basic version of PPP and the dll is built upon that platform. The extended version contains some more VLE models and some more advanced process models. but I felt the basic version was the best option. As an independent consultant, I needed a low cost access to a good databank that would provide the properties needed for vapor/liq and vapor/liq/liq equilibria for a large number of compounds. The PPP system provides that and a bonus of the functions for stream and databank interactions.
Although engineers in large corporations have access to large, expensive physical property databases, they too may find this PPP/Mathcad combination to be an attractive option. Mathcad is often used when modeling special problems that the process simulation packages can't handle. With the addition of PPP, the Mathcad simulation can easily handle phase equilibria, both ideal and non-ideal. In addition, properties such as heat capacity, viscosity and heat of formation are readily available within the program. This saves time obtaining the required input for the simulation.
This Mathcad/PPP system is not intended to be a complete process simulation package. I anticipate using it for very small sections of a process, say a reactor with an overhead condenser. It also could be used for looking at multiphase problems in tubes or porous media, for example.
At this time, I don't know what arrangements PTC and Prode will make regarding pricing and delivery. That may depend upon customer interest. If you are interested, please vote in the poll here.
Oscar Delgado provided a Prime 1 worksheet that sized an air receiver using the SRK equation of state and water vapor pressure from an Antoine equation. I have written a Mathcad 15 version using PPP. The pdf version of that worksheet is attached. The PPP version doesn't require coding of the equation of state or the vapor pressure equation. All properties needed by those equations are already provided by the databank.
You may read more about the Prode software at prode.com.
Acknowledgements: Chris Hartmann (no longer at PTC) helped obtain the development support. That support was provided by John Sheehan.
