On 11/12/2009 1:23:30 PM, Richard_Oliver wrote:
>Thank you, I have replaced
>version 14 with version 11
Unfortunately, as Tom has chosed to save his worksheet as an M14 xmcdz file I can't read it to see what he's proposed.
However, looking at your worksheet, there would be a lot of work to rearrange it into a function. One possible way to get what you want is, as suggested earlier, to use animation.
I've chosen to use a master&reference worksheet approach. I've disabled Wing1CL and saved your worksheet as the 'reference' worksheet. I've then created a 'master' worksheet that generates an appropriate value of Wing1CL *prior* to 'referencing' your worksheet. I use the Animation FRAME variable to set the value of Wing1CL. You then need to run the Animation to create a file of results that Mathcad can then read back in - you may have to fiddle around with the values to get of the extraneous values.
You could have used the FRAME variable approach directly within your worksheet (example attached) - but I found it easier to muck around with a clean worksheet.
Stuart
