Thank you. No bad feelings. I've been playing with Stuart's looping file from the other thread. Thanks to his program, I've modified and expanded, all while learning about what is preached in this collab. Your help is appreciated and I do learn from what you send. Just keep in mind that items posted may/may not be fully documented for various reasons.
See Richard comment about proprietary
(http://collab.mathsoft.com/read?130528,18).Yes, sometimes as a power user/tutor, you may need to read into what is requested due to poor wording on the posters part (again, Stuart reading into what I was requesting)
I am not doing rocket science, just re-writing/re-creating excel sheets etc. to make them more traceable. In the process, I have found numerous issues that justify some previous test systems problems (i.e. motor spiking/tripping fuse due to being fractionally too small 1.25 HP installed ... needed 1.5 HP).
