8-Gravel
September 3, 2020
Return (several) plots programmatically
  • September 3, 2020
  • 2 replies
  • 2263 views
Hi!
Is it possible to return a plot in MC15 from a progam?
Background:
I have multiple excel files with data.
Using the READEXCEL i want to take the data for each file and plot a fitted curve (polyfit(X,Y,2)) for each file
I cannot find any commands to output a plot
Siggi
Best answer by LucMeekes
Mathcad is not Matlab. That is: it is not a programming language.
Inserting a plot on a worksheet can only be done by user (interface) action.
What you can do is insert a plot, and adapt it to your needs. Then copy it as many times as you need on the worksheet and feed each plot with data from a file source (data file, excel file, whatever), by just changing the file name. That should work fine if all your file sources are structured similarly (if not equally).
LucMeekes23-Emerald IVAnswer
In Mathcad a plot is not an object which can be stored in a variable or can be the result of a function.
But you sure can write a program which takes the Excel file name and returns the desired function.
Not sure if the following example comes close to what you are looking for:
snã¦ss8-GravelAuthor
8-Gravel
September 4, 2020
Thank you @Werner_E  and @LucMeekes !
Quick follow-up regarding plots:
Is it possible to link the plot title to e.g. a vector containing the name of the files?
So when I enter a new list of excel filenames, the plot titles would automatically update
Siggi
Quick answer: No.
The plot title is not a variable accessible from within mathcad. It, like the rest of the plot, can only be entered through the user interface.
What you can do is, if the file name is a (string) variable, evaluate that variable above or on top of the plot.
