SRIPT EDITOR
johanpg
SRIPT EDITOR
Hello I am new using script editor, and I think it is a very nice tool, but I have a problem, every time I save a close the file that has the script editor, it does not save my selection, it initialize with the first selection in my string content..., I think it is because the:
Rem Initialize Selection If desired
ListBox.CurSel = 0
Could you please tell me how to keep my selection once I exit the file???
Thank you!!! BTW I am using MathCAD 14
Rem Initialize List Box
ListBox.ResetContent()
Rem Add Strings here as needed
ListBox.AddString("24f-E (DF Only)")
ListBox.AddString("24f_Ex(DF Only)")
ListBox.AddString("20f-E")
ListBox.AddString("20f-Ex")
ListBox.AddString("18t-E (DF) / 14t-E (SPF)")
ListBox.AddString("16c-E (DF) / 12c-E (SPF)")
ListBox.CurSel = 0
Sub ListBoxEvent_Start()
End Sub
Sub ListBoxEvent_Exec(Inputs,Outputs)
Outputs(0).Value = ListBox.CurSel + 1
End Sub
RichardJ
(To:johanpg)
See this thread:
http://collab.mathsoft.com/read?114426,63e#114426
There are a couple of examples, in the second and fourth posts.
Richard
Hello Richard,
Thank you for your help. I used the Metadata to save the values on my ListBoxState.
The issue I have now, is that I am using the same ListBox, with different Inputs in different locations of my calculations.
When I save the file close and reopen it, all my values are now set as the one I saved the last. Is there any way to keep the values as their original input??
Thank you,
Johan
>Is there any way to keep the values as their original input?? <<br> _____________________
Save them in file.
How could I save them in file?
Thank you,
Johan
