Shading Graph
MikeArmstrong
Shading Graph
Does anyone have a fucntion or neat way to shapean area under a graph?
I guess you can find a lot of nice ways to shade, color, hatch an area in the "Amazing Images" E-Book.
Byrge Birkeland also had posted a sheet (unfortunately Prime) specifically about shading a region here:
http://communities.ptc.com/docs/DOC-3495
Some other link which might be of interest:
http://communities.ptc.com/message/205924#205924
http://communities.ptc.com/message/158074#158074
http://communities.ptc.com/message/233004#233004
In your case you might first define a piecewise function following your horizontal marker and then the green line and use bars or error bars to shade the area underneath.
8 REPLIES 8
Thanks Werner,
A few good examples, but no easy way to achieve such a simple task.
Mike Armstrong wrote:
Thanks Werner,
I agree that shading/filling/hatching an area should be a feature out of the box. In the meantime we have to do it ourself, sort of write-once/use-many.
In your case its even more difficult because you switched dependent and independent axis (so error bars won't work) and you also changed the orientation of the vertical axis (so showing the hatch as a bunch of points doesn't work in the attached sheet).
Werner, your Mathcad capabilities and commitment to this forum never cease to amaze me.
Cheers
Here is a much quicker AreaFill routine. As you can't show a dotted area anyway there is no need for the numerous intermediate points which the other routine creates.
I am also cheating on the boundary values of the plot to be able to show the border.
Nice, very nice indeed. I think will be going in the collection.
I've had to do that before. Anther example of poor performance, but no moaning tonight
Yes, we can influence the order in which the various plots are made and can put the hatching first so it is overwritten by the graphs. But we cannot influence when the axis or box borders are drawn.
It may make sense for a graph to overwrite the axis, but I guess it seldom makes sense if it overwrites the borders if box style is chosen. An option, something like "axis always on top", would be useful. But when I look at the quality of Prime's plots .... just lets be happy with what we have in Mathcad 15!
Yes, I was thinking of suggesting you create an idea, but as you said, Prime's plots need a substantial improvement before additional features are recommended/implemented.
