Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Solve Block in Program
BillWalsh
Is it possible to include a solve block as part of a program?
6 REPLIES 6
PhilipOakley
(To:BillWalsh)
Yes and No. Or is that No and Yes.
You can set up a solve block to have a functional
form where you pass parameters and it returns solved
results (examples in the help)
You then use that function in the program.
So, as a precise answer, you can't have a solve
block in a program. It is two (obvious) (in
retrospect) steps. Actually, making it two steps
usually makes it easier to debug and maintain.
Philip Oakley
Thanks Phil,
I'll give it a try
Bill Walsh
>program?
__________________________
Mathcad 11.2a
YES, you pass root as is and pass Given/Find as a function
... Odesolve, all math matrix ...
You can't pass Maximize/Minimize, Minerr.
You can pass linfit and maybe few more.
For Minerr, we use an indexed iterative loop.
jmG
I'll give it a try.
Bill
On 7/19/2009 10:56:04 PM, BillWalsh wrote:
>Thanks, I'll give it a try.
>Bill.
The best will be the work sheet itself.
If you "Save as" version 11 or lower,
a very large audience will collaborate.
jmG
