Symbolic Evaluation Variable Assignment Problem
- October 2, 2015
- 2 replies
- 5628 views
Hi all,
I was seeing some strange inconsistencies between sheets when attempting to evaluate expressions symbolically. After some time I traced the inconsistency back to the "point" shown in the attached sheet.
The attached sheet shows what I expect to see. After evaluating a function and assigning the result to a variable, the symbolic evaluation shows the result.
However, in a different worksheet, I see the following:
For some reason, Mathcad is presenting the result as the original function. I'll post the problem sheet if necessary, but as you can see here, Mathcad has already found a numeric solution and assigned it to a variable, and has even managed to display it when called up again. But when I use the symbolic evaluation on it, it brings up the whole function. But in the attached worksheet, it does not.
Any ideas why this happens? Or at least, why the difference between worksheets?
Any advice is greatly appreciated.
