Symbolics Question
ELSID
Symbolics Question
I do not think this is a bug, so I am posting here.
Is there a way of having Mathcad move the constant to the denominator instead of calculating the value and truncating to the set number of decimal places?
BTW, �T was set to 21 İF
5 REPLIES 5
If you want exact solutions, don't use decimal points in the numbers. The presence of a decimal point forces floating point evaluation by the symbolic processor. But that is generally done with the default 20 digits. I don't know how you got truncation. It also seems that you may have been using the menu (dead) symbolics rather than the usual live symbolics.
__________________
� � � � Tom Gutman
It isn't. It's a round-off error.
It's a convention that numbers whith decimal dot are "at machine precission" rationals, or "realcons", or other names, depending the language, including for example RPN from Hewlett-Packard.
Actually, it's a short hand for declaring float point values. You can input 1.08 as 108/100 to avoid truncation errors. The reciprocal is true: to input values like 2 as floating point write 2. or 2.0.
Im mcad/maple you can write convert(expr,rational) to have all values as exact ones, and I remember a bug in mcad14 related with truncation and laplace, but searching in the forum seems broken.
Regards. Alvaro.
PD: Time ago I discover that users with a long experience using microsoft word find death symbolics comfortable.
You wouldn't be under stress,
had you left the Mathcad default in place before modifying.
jmG
ELSID
(To:ptc-1368288)
Looks like all 3 are saying the same thing. How would you implement the "usual live symbolics". I got the procedure from one of the e-books ... probably outdated
>>How would you implement the "usual live symbolics".<<
ctl-alt-. symbolic evaluation. That's what should be the major part of the help for symbolic calculation.
__________________
� � � � Tom Gutman
