The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
single quote? - how to bracket expression?
PhilipOakley
I may have missed it in the documetation:
a) how to put brackets round an expression to go from a+b to (a+b) so that one can procede to (a+b)*c
b) what does the single quote ' now do?
I see that after expanding my selection, it placed brackets around the expressiona, but also added the ' which then gave an error. [is it the differntial?]
Philip Oakley
>documetation:
>procede to (a+b)*c
>' now do?
>differntial?]
>Philip Oakley
You can do as in the current version, spacebar, spacebar,*
I don't get any single quotes when I do that, and if you spacebar it, you can get the parentheses to go around both, as well.
TTFN,
Eden
PhilipOakley
(To:IRstuff)
OK, I use the apostrophe a lot just to sort out groupings, and to post-facto, stick a function around the expression, etc.
searching the ribbon found "Prime (')" under Maths/Operators/calculus - Not sure I'd call the operator "Prime"
Philip Oakley
Inserting parentheses is now done with the parenthesis key, not the single quote (which is now a function derivative).
__________________
� � � � Tom Gutman
