solve block as a function 2
MikeArmstrong
Stuart
Would you be able to suggest a function for the attached calculation?
L= wave length
My aim is to have multiple values of T & d.
Regards
Mike
10 REPLIES 10
On 8/25/2009 7:28:33 AM, Armo wrote:
== Would you be able to suggest a function for the attached calculation?
== L= wave length
== My aim is to have multiple values of T & d.
Something like the attached, using a numerical solve block?
Stuart
MikeArmstrong
(To:StuartBruff)
Stuart
Please find the attached.
Regards
Mike
On 8/25/2009 8:02:02 AM, Armo wrote:
== Please find the attached.
Sorry, Mike
I've only got M13 at the moment, so can't read your M14 worksheet.
Stuart
MikeArmstrong
(To:StuartBruff)
My bad.
Regards
Mike
On 8/25/2009 8:18:01 AM, Armo wrote:
Mike,
apply the vectorize operator to make the function loop over each element of d - won't work if T is a vector, then you'll need to create a range variable (as per my previous example) or a program to loop through each element)
Stuart
MikeArmstrong
(To:StuartBruff)
Stuart
I think with your help it is sorted, see attached.
Cheers for the help
Regards
Mike
Could you repost the file, without all the % symbols in the filename. We can't download files if they have certain characters in the filename (to be safe, use only alphanumerics and - _ ( ) ).
Richard
On 8/25/2009 8:47:39 AM, Armo wrote:
== I think with your help it is sorted, see attached.
My Mathcad probably wouldn't like the worksheet because it's an xmcd file, but that's a bit of a moot point as my IExplorer won't download it (I imagine it doesn't like the '%20' space characters).
Stuart
MikeArmstrong
(To:StuartBruff)
repost
Regards
Mike
You don't need the local assignment in the definition of Wave. If you delete "a<--" it works just the same. All you are doing is assigning the results of the calculation to a local variable "a" (the left shaft is a local assignment, and "a" is only defined within the expression - you can't access it somewhere else in the worksheet), and then assigning the contents of "a" to "Wave". Since you don't use "a" for anything else, it's not needed.
Richard
