Design Advisor does not complete analysis
DanAdler
We are running v20.6.1 and are unable to get any FEA jobs to run successfully using the Design Advisor module. We opened a support ticket late last year and were directed to the SPR linked below.
Design Advisor hangs during Performing Analysis and does not finish the job with special computer environment in Creo Elements/Direct Modeling
To date there does not appear to be a resolution to this issue. The enhancements documents for later releases, including v20.7, do not indicate that this is resolved.
Has anyone else encountered this issue? Do you have any workarounds to offer?
Thank you for your help
MagicMike
(To:DanAdler)
We also have this issue at a customer's site with v20.1 (not supported anymore).
It looks like the problem occurs on different/special hardware because the customer switched to another PC and there it works fine.
