Product idea - Inseparables behave as part in BOM
PJVB_SVC
7-Bedrock
This message can also be found in the product ideas.
Inseparables are used to show/save an assembly as part.
Currently, while scanning the BOM an inseparable is handled as an assembly instead of a part.
This leads to errors in the BOM list.
- main assembly
     - part 1
     - part 2
     - inseparable 1
          - part 3
          - part 4
     - sub assembly 1
          - part 5
          - inseparable 2
               - part 6
               - part 7
Setting "Scan Inseparable" = "OFF" (Anything located below an inseparable is used as BOM entry)
=> OFF = The inseparable will be calculated
=> ON = The inseparable will be ignored, parts will be calculated separate
Current outcome SCAN ALL LEVELS:
- part 1
- part 2
- part 5
Expected outcome SCAN ALL LEVELS:
- part 1
- part 2
- inseparable 1
- part 5
- inseparable 2
Hi @PJVB_SVC
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
