STP files
GeneGoldenberg
STP files
Does anybody know if STP file can have material of the original parts info stored?
Not sure what the spec says,
I did a test of a Step out and Step in and the imported file had no material set.
But material could be an optional piece of the output that PTC does not transmit.
I have a Step file from someone and it has color in the file, but my test file does not.
Hi the following article drops some hints : https://www.ptc.com/en/support/article/CS59472
EG_FL33433
(To:remy)
Thank you much
Hi @GeneGoldenberg,
Anurag
