am_save_sheet_dwg/f2_core/unknown_error
  • December 14, 2022
  • 2640 views
Hi all;
When I want to save dwg file from annotation module, I am taking following error;
"am_save_sheet_dwg/f2_core/unknown_error".
I need help, thank you very much
    Best answer by Ertan_Akbayir
    Hi;
    The problem was due to different windows session. I dont take error in other windows session. Thank you for your reply. The lisp seems very very useful but I couldnt use it. I use 20.4.1 version.
    Thank you very much
    Are you saving with the save window from the menu bar?  Or are you using a lisp file or typing in the a save command on the command line?
    I use save command,
    Is this a new issue?  Or has it always been an issue?
