Probability and Statistics
Sir Kindly arrange to provide the detailed notes for the following questions. 1. When is it appropriate to use the uniform distribution to describe a random variable X? 2. Why do we compute values when using the normal table? Explain. 3. Explain the meaning of the height of a probability curve over a given point. 4. Explain: a. what the mean �, tells us about a normal curve. b. what the standard deviation σ, tells us about a normal curve. 5. Explain how to compute Z value corresponding to a value of normality distributed random variable. What does the Z value tell us about the value of the random variable. Your earliest reply in this regard will be much more appreciated and also useful for me class tutorials.
RE: Probability and Statistics
Hello Sir, Can you please provide more details for your questions? How are you using Pro/E in this class? What material are you referencing? Thank you, Mark
Welcome to PTC Academic!
